can i used hydro carbon serive valve istead liquid service valve the valve have same cv
i have fuel control valve 1' reduced bore 3/4" have ascertain cv service fluid is hydro carbon gas
and I have at some where automatic drain valve have same size and bore size service hydro carbon liquid installed and scrubber drain
can I used the first valve instead the second valve the two valve have same size and same cv but different in service media which handling
RE: can i used hydro carbon serive valve istead liquid service valve the valve have same cv
