Title block moving
Title block moving
When I start a new draft (master model) normally I chose the A3 format. Sometimes I adjust the format to A2 Or A1. The thing is the position of the title block.
When I start with a blank A3 format (without views etc) and change the format to A2 the title block moves as expected.
When I have a A3 with a drawing view already inserted and then changing to A2 the title block does not move.
What can be te cause of this behavior?
Lars
NX11.0.1.11 native
Solid Edge
Inventor
RE: Title block moving
What I can imagine is that when you plce views with the View Creation Wizzard and use the automatic scaling it locks the position of the titleblock.
Not sure if this is the case though.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Lars
NX11.0.1.11 native
Solid Edge
Inventor
For me it is not happening. When I change the sheet size the O.O.T.B titleblock and frame adjust without issues.
NX9 / TC10.1.2
