SEAL OIL TANK LEVEL DECREASING CONSIDERABLY
ONE OF RECYCLE GAS COMPRESSOR (PIGNONE-WITH SUCTION 660 AND DISCHARGE 760 PSI) ,DRIVEN BY STEAM TURBINE SHOWING A PROBLEM FROM LAST FEW DAYS.ITS SEAL OIL LEVEL IS CONSIDERABLY REDUCING SOME TIMES.THE SEAL OIL TANK CAPACITY IS 14 BARRELS AND OVERHEAD TANK 1.5 BARREL RESPECTIVELY AT MAXIMUM LEVEL AND 75% FOR OVERHEAD TANK.IT IS EQUIPPED WITH A DEGASSING FACILITY.THERE ARE TOTAL 4 VENTS FROM THE SYSTEM, 1,SEAL OIL TANK TO ATMOSPHERE.2,DEGASSING TANK TO ATMOSPHERE 3,MIST ELIMINATOR TO KNOCK OUT DRUM 4,JUST BEFORE THE MIST ELIMINATOR AND AFTER THE SEAL TRAPS TO HIGH VENT.THE KNOCK OUT DRUM IS NOT SHOWING ANY SIGN OF OIL IN ITS DRAIN . YESTERDAY WE ADDED ALMOST 25 BARRELS OF OIL.WHILE OUR OBSERVATION WE SAW SOME MALFUNCTION IN THE PDCV. THE ACTUAL PDCV SETTING IS 660+120=780 PSI , BUT WE FOUND THE SEAL OIL PUMP DISCHARGE PRESSURE 1000 PSI.WE REMOVED THE PDCV AND OPEN THE BYPASS FOR REGULATING THE PRESSURE.IN WHICH WAY THE OIL IS LOSING ?ITS AN OLD MODEL (BELOW 1980) COMPRESSOR.IS THERE IS CHANCE TO MIX WITH THE PROCESS GAS? {THERE IS A SIGN OF FLOATING SEAL LEAK}.
RE: SEAL OIL TANK LEVEL DECREASING CONSIDERABLY
Johnny Pellin
I had made a number of assumptions based on your last post. It now seems that many of my assumptions may be incorrect. Is this an Iso-Carbon, Iso-Sleeve, cone or bushing seal? The differential pressure control valve that you are talking about seems strange to me. I would expect the pump discharge pressure to control to a fixed pressure by spilling the excess oil flow back to the reservoir. Downstream of that, I would expect a separate differential pressure control valve to make the final drop to hold the seal oil DP for a bushing seal, cone seal or iso-carbon seal. I would expect a level control valve to hold constant level in the overhead seal oil vessel if it is an Iso-Sleeve seal. If your PDCV was holding 1000 psi (340 psi above compressor inlet pressure) were the seals exposed to this full differential pressure? If so, you may have damaged the seals or blown out o-rings.
In any case, if you are losing oil but it is not migrating into the lube oil and it is not running out on the ground, then it must be going into the process. I cannot say with more certainty without a seal drawing and an oil system diagram.
Johnny Pellin
Regarding the oil migration problem I have noticed in one more compressor also.Lube oil tank level increasing and seal oil tank level decreasing.
