Strut and tie for "Deep Beam" above opening in foundation wall
Hi folks!
I'm assessing an existing foundation wall with a large opening which effectively forms a 10 ft span x 10 ft deep x 4 ft wide "beam" above the opening. There is longitudinal reinforcement in the bottom of the "beam" but not a sufficient amount to act as a tied arch in a strut-and-tie assessment (see attachment, top image). If I was designing it new, I'd provide enough steel there, but alas it's been around longer than I have, and now there's a question of whether the load on it can be increased.
My thinking is that since it's a very thick wall, it would be reasonable to take the thrust from the compression struts as a horizontal compression load (over an area based on the S&T node size) and check that the walls can carry the load, rather than relying on the rebar at all (see attachment, bottom image) - essentially an arch with abutments rather than the tied arch you'd typically consider in a strut and tie model of a simply supported deep beam.
I'd appreciate any thoughts on this approach. I recognize that the failure mode would be brittle because it's not based on rebar yielding, but I'm thinking if the capacity is high enough this would be justifiable.
RE: Strut and tie for "Deep Beam" above opening in foundation wall
BA
BAretired - external reinforcement is an option being considered as well. Just trying to cover all the bases before recommending too much remedial work.
KootK - yes, tied into a thick slab at the top. Will definitely have to check that the whole thing is tied down sufficiently.
Toby43 - thanks for the comment, much appreciated. Definitely needs assessment of the full load path.
