Identify results on multiple viewports - NX Simcenter
Hi All,
In NX Simcenter, when post-processing results, I have 2 viewports open (side by side). I have slightly different results in each viewport for the same part in order to compare. I have then used the 'Identify Results' icon to select the individual nodal stress at a given node (see attachment). Now I'd like to have that value show up on both viewports to take a picture for reporting purposes.
I don't seem to be able to show the numerical value for the node in both viewports because on closing the dialogue box for the first viewport, the numbers are cleared.
Any help will be greatly appreciated.
Thanks in advance.
http://files.engineering.com/getfile.aspx?folder=2...
Thanks in advance.
RE: Identify results on multiple viewports - NX Simcenter
