Change Size of 3D Text
hi, all, I just got a new laptop with a very dense 15" display. I've managed to scale the toolbar icons with the system, but the text, dimensions, and constraint symbols in the viewport are very small and hard to read in comparison to the rest of the UI. Is there any way to increase the size of these elements?
screenshot:
screenshot:
RE: Change Size of 3D Text
but first you want to check your units: Tools + Options + Parameters and make sure the Length in set for Millimeters
The constraint size looks correct to me. I've never been able to figure out how to change the size either.
The tree diagram looks awfully small. click on the white axis in the lower-right corner to make the tree active, then zoom with the mouse to change the size. When you're happy, click on the axis to re-activate the sketch.
Also if you want to resize the text in the specification tree you can use Ctrl + Zoom wheel on mouse.
Best regards,
Costin Ruja
