creating a reference planes/axis system in catia assembly
how to position first component properly so that when front,side,top vies are taken part is alligned properly? while repositioning i rotated the component and now i dont know how to adjust as there is no reference plane/axis system to give constraints?pls find the attached image. when side view is taken view is not right.
RE: creating a reference planes/axis system in catia assembly
After this, select the view that you want to reorient, and click properties icon. Then orient it as needed.
You can skip this, by moving the component. For that use the compass.
Tiago Figueiredo
Tooling Engineer
Youtube channel:
https://www.youtube.com/channel/UC1qdlBeJJEgMgpPLV...
But I have a few extra steps:
1. Insert a new part, and immediately fix it
2. apply a coincidence constraint between the axis of the new, dummy part and the axis of the first component
3. fix the first component
4. delete the coincidence constraint from step 2
5. delete the new, dummy part (it's no longer needed)
I discovered that it saves me alot of time and aggregation to always fix that first component as soon as I insert it into a new assembly.
