Thermal Flow in Ceramic Material
Hello there fellow Eng-tips people,
I am doing design of Ceramic Housing that is exposed to Conduction (Oven Grill).
I need some help on how to compute the inner temperature and time before the inner surface reaches the same temperature as its outer wall
Reason is, I want to get the appropriate thickness of Ceramic that can maintain a good internal temperature in a given cooking time.
Thanks for the help!
RE: Thermal Flow in Ceramic Material
Will it be Fourier's law or another Heat Transfer equation?
I need it to be transient so time is essential to determine the temperature
Can you advise on how to get the right computation.
prex
http://www.xcalcs.com : Online engineering calculations
https://www.megamag.it : Magnetic brakes and launchers for fun rides
https://www.levitans.com : Air bearing pads
