bystar 3015 mmc problem
If someone can help with the configuration of the MMC?
Machine does not start gases for cutting (O2 N2) - is only activated cooling nozzles...
Problem appeared after the backup of the entire system from DVD disc to HDD.
RE: bystar 3015 mmc problem
are you able to get the gasses to work in manual mode with the hand control?
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
I can not. Gases do not work ever.
Also selection of the channel 1 or 2 does not work.
Absolutely nothing.
I think that the configuration of the MMC is not good.
Thank you for your help in solving our problems...
I'm not sure what you mean with: "Maximum Up-time, Minimum BS "
Do you have a good "save everything" set of files? If you give me the romram and MMC version I might have one.
I do not have a recorded file.
This machine is the customer bought in working order and when transporting the machines - hard drive is broken.
With the machine they are getting CD and DVD discs with backups hdd from 2010 years.
I'm cloned a new HDD with those discs and everything works perfectly except gases...
MMC version is : P6016
CNC version is: p6110F
please - help
before I started messing with the control I would check the fuses on the front of the gascon. You can also try connecting the jucomatic valves directly to 24 volts to see if you have gas flow. Where are you located?
I am from Serbia, but machine is in Croatia..
All the fuses on the Gascon are ok.
Tomorrow I will try gascon on another machine.
I tested both valves directly from 24VDC and in this case there is a flow of gas.
I've tested all ...
gasregulator = OK
valves = OK
MMC?
Any ideas?
check the current going through the pressure transducers
