Trim 8 3/4" S 800 NPT gate valve
Hello again colleagues. It is acceptable to sweep the thread of a NPT valve to be able to use it as a SW. I have rejected it, some suggestion about it, regardless the line service that I do not remember, but I am sure they are for drainage,
Attached photos,
Best regards
Attached photos,
Best regards
RE: Trim 8 3/4" S 800 NPT gate valve
If it's the case, the only option is to make sure the right material based on the right Code.
