Bolted bonnet Trim 5 Gate and globe Valves Seat rings welding
Hello colleagues. I recently started working at an oil company. When I received KSB valves, which came directly from the factory in China, I found that the rings of the valves of 4 "and smaller in diameter, regardless of the #, have the welding of the seat rings to the body, undercut greater than 2 mm, under fill of 1,5 mm, etc. etc, in most of the cases all the way around. The truth, what I think, the valves are recovered from scrap and are being sell as new, given that the body areas, around the rings, are seen as eroded, with slug that seems more due to corrosion than to the mill cast. I have rejected the whole lot, after doing a random inspection to 10% of the total, because a contractor is having the same problem with valves of the same mark. Any suggestion, about the criteria of rejection of the welding of those rings to the body of the valve?
Attached photos,
Best regards
Attached photos,
Best regards
RE: Bolted bonnet Trim 5 Gate and globe Valves Seat rings welding
