Block shear for welded connection
Does anyone have any guidance on evaluating block shear (tear-out) for a tension-loaded deep channel (C-section) only connected at its web, with a series of elongated ring welds? Can I assume the same fracture paths as with a bolted joint or is that too conservative?
tg
tg
RE: Block shear for welded connection
