mechanical design of motor parts
Hii,
Can someone suggest me any good resource or reference about designing and tolerating mechanical parts of motor like Shafts, Housing, EndCovers and bearing selection.
Please refer the attachment for more details
Thanks and regards,
Thanks and regards,
RE: mechanical design of motor parts
Drafting standards like ASME Y14.5-2009 are standard across the industry. You can apply it to motor parts, to nuclear reactor parts, and to axe handles. You need to work out the motor works, and how the parts will be fabricated and assembled. The drawings will follow logically.
JHG
You need to figure out the loads on the bearings before you select any bearings.
Here is an engineering handbook from SKF that covers electric motor/generator rolling element bearings.
R.Efendy
