Selected remote point location is different from hit point location
I am conducting a harmonic response analysis of a shaft. I put point masses for corresponding rotor parts to include mass and inertia effect. I applied "rotational velocity" in the modal analysis and "rotating force" under Harmonic response section.
My problem is, during rotating force configuration, i defined location by giving a remote point. I gave the same remote point for Hit Point selection. However, program gave me an error as "Selected remote point location is different from hit point location". The truth is they are the same.
Do you know what might cause this problem?
