Piled Raft Design - Subgrade Modulus - Pile Spring Stiffness.
Dear All,
Designing a RC piled Raft. medium dense clay of approximately 100kn/m2 CU value. Just want some friendly advice.
2 options as i see it
1. model the raft as a slab supported on a continuous set of springs. The K value (modulus of subgrade reaction) is required? No plate bearing test has been done on site and with no geotechnical specialist involved either, is it acceptable to just assume a very soft sub strata with K value of 5000kn/m2/m? springs at 1m c/c's would therefore result in 5000Kn/m k value for my model.
Model the piles as springs? No deflection values have been provided by a piling specialist.. again is it acceptable to assume a value here? I wouldn't even know where to start?
2. Or alternatively is it simpler to design the slab as a flat slab? this would ignore the concrete soil interaction and assume all the load to pass through the piles? Or is that unreasonably conservative, i imagine the rebar tonnage would rocket?
Thank you in advance.
RE: Piled Raft Design - Subgrade Modulus - Pile Spring Stiffness.
As far as the model goes: yes, I've seen some people in such a situation treat the mat like it's sitting on air. Off the top of my head, I'd say that is probably the worst case scenario for the mat/raft and the piles. But you are still going to need a geotechnical report to give you the proper info on those piles.
