Fire case validity for a tank in a remote location
Hi folks,
I'm evaluating the need for fire sizing the PSV on a condensate tank that is located away (~1000 ft) from the general processing area. The closest source of a fire is 40 feet away. There are two other tanks that have their own containment. There are no other sources for a flammable pool of liquid to form / drain directly underneath the condensate tank. Any thoughts on whether liquid pool fire sizing would be a credible case?
Thanks.
Thanks.
RE: Fire case validity for a tank in a remote location
Is it oily water?
The feed is coming off the high pressure dumps from the Amine, Dehy, and residue compressor systems. About 40% water, and the rest hexanes through decanes.
Liquid pool fire sizing is definitely a credible case.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
No one knows what size the leak will be, so consider the possibilities and go with the worst credible case.
Good luck,
Latexman
If you could model this on Hysis or Pro / II with the firecase relief utility, you'd get even lower vapor generation rates ( when compared to the old fashioned manual calc method).
