Manlift load on a checker plate floor
I appreciate if someone that knows the steps of checking a checkered plate floor is okay to carry loads of a manlift on it.
They are intending to place a manlift on 17 floor of an open steel structure tower that is covered by a checker plates.
Any Excel sheet or sample calculation that can help me through
I greatly appreciate for your kind direction and help.
I need the design steps to follow. This is just checking and not designing.
Thank you
Thank you
RE: Manlift load on a checker plate floor
You can try modeling it any FEA program (RISA would be my choice).
You can consult Roark's Formulas for Stress and Strain. pdf here http://materiales.azc.uam.mx/gjl/Clases/MA10_I/Roa...'s%20formulas%20for%20stress%20and%20strain.pdf
The link doesn't seem to work but just google "Roark's Formulas for Stress and Strain"
I don't have any FEA software.
Couldn't find Roark
Any hand calculation any handbook example
They need it quick and I am at the corner trying to help
Thank you so very much for the document.
May I ask what page and how I use it to check if the checker plate is adequate for the manlift load?
Thank you
Dik
Determine the plate strip width taking the wheel load per plate thickness and wheel dimension
Check the bending of the plate strip considering the membrane force
Check the welds between the plate and supporting members per the membrane force in the plate
Thank you very much.
Shu Jiang, P.Eng, PE (Structural),
Thank you by the chance do you have a sample calcs?
Dik
It is not easy do the calculation manually. I have a ansys apdl command file if you need.
Thank tou is very kind of you offering it but where I am working they don't have ANSYS !
Anybody has a copy of the book that deal with wheel loads on slab on grade? Is it the same technic I need to use?
Thank you
http://www.eng-tips.com/viewthread.cfm?qid=394262
