CSA A23.3 Concrete Wall Design
As my previous post explained Link, the Canadian company I work at will soon be getting into mid-rise concrete building projects. I’m involved with making a software selection for the company in order to assist us with the design of these projects. I’ve done some pretty extensive research on RISA (3D, Floor ES, Foundation), which has seemed quite promising. My concern is the lack of CSA A23.3 code support for concrete wall design (gravity and lateral). After speaking with someone at RISA I’ve confirmed concrete wall design to CSA A23.3 will be supported in RISA Floor v13 and RISA 3D v17. It seems like foundations, columns, beams, and slabs can all be done as per Canadian code currently which is a perk. I’m curious how the Canadian engineers who have RISA deal with this? Do you ensure the reinforcement/wall thickness is correct to determine the loads in the walls then design using spreadsheets? The other software option we’re considering is the CSI America programs (ETABS, SAP2000, SAFE) due to their Canadian code support.
RE: CSA A23.3 Concrete Wall Design
Dik
I then use spreadsheets for design in concrete or steel or a couple of programs I wrote in Delphi... conc columns, walls, interaction diagrams and biaxial bending...Other than support conditions, and they depend on how I model them, I have 100% confidence in Risa's output.
Dik
Anyway, Shotzie, did you end up making a decision on which way to go? From my research, it seems that there is much more help/resources around for Risa3D. Maybe I just haven't found where all the ETABS users are hiding on the internet.
I believe we will end up purchasing some RISA programs, but the focus of those would be for miscellaneous wood structures, such as timberframes, and potentially using them for midrise wood structures.
I just remembered that I did do a multi-storey building with concrete shear walls, and what the majority of people at our office would do (and what I was taught) was to copy/paste the output from ETABS into S-Concrete for each wall. Not sure if you've used S-Concrete but it's excellent for checking hundreds of load cases and it has a great user interface that allows for quickly trying out different reinforcement options.
