NX10 sketch angle dimensions using rapid dimension
When creating angular dimensions using "rapid dimension" in sketch (recently installed NX10) - I'm getting good preview but the very moment I place dimension it jumps to complement angle. Do I have wrong setting somewhere? - As workaround I have to switch to angular dimension function to get it right.
Thank you.
NX10 + TC10
RE: NX10 sketch angle dimensions using rapid dimension
Yep this is a known issue in NX 10. It gets fixed in NX11. I do not know if it gets fixed in a later pack or release for NX10. You may be able to contact GTAC to see if this got fixed. We moved to NX11 but I think it was broken up until we moved.
Thank you.
NX10 + TC10
