Is there any other experimental method to determine the bending rigidity of a sandwich?
is there any other experimental method to determine the bending rigidity and shear stiffness of a sandwich (three-point bending test) outside Allen's method?
Allens method is described in his book "Analysis and Design of Structural Sandwich Panels" on page 258
Thank you
Thank you
RE: Is there any other experimental method to determine the bending rigidity of a sandwich?
best forum
