Live Load and Snow Load Combination
Hello All,
I am designing what was once a single story building with a flat roof, into essentially a deck. The columns are fine, but the wood beams need to be resized. The problem I am running into is that D + L + S is giving me a high value. The deck is to be used for socializing, so when there is a snow load present there will not be a live load (people). Do I just ignore the snow load and assume dead + live because the more conservative approach (D + L + S) probably won't occur at the same time? Or is there a rule-of-thumb that I am not aware of.
Thanks!
Hot Sauce
Thanks!
Hot Sauce
RE: Live Load and Snow Load Combination
Mike McCann, PE, SE (WA)
