Applying torque/moment to a buckling analysis
I need to perform a buckling analysis on a weldment at my job. There is a leg that swings, much like a clock pendulum, between two plates. We have created an I-beam type weldment to mount this leg.
In all my reading, it seems buckling is determined based on a single force. This set-up leads me to want to use a torque/moment applied at the pinning point. Is that valid?
Why do you have to be a nonconformist like everybody else?
- James Thurber
RE: Applying torque/moment to a buckling analysis
