nx nastran do not write the results file
I just update to NX-nastran R11, but now when I try to do any simulation ( simple cantilever beam) it do not write any results file (V only .dat and .diag) . However the information windows shown "Nastran Deck Successfully Writte".
Any suggestion
Solution Model Setup Check Error Summary
Solver is NX Nastran
Environment: NX Nastran - Structural
Solution is SOL 101 Linear Statics - Global Constraints
Mesh-Based Errors Summary
Total: 0 errors and 0 warnings
Material-Based Errors Summary
Solution-Based Errors Summary
Iterative Solver Option
More than 80 percent of the elements in this model are 3D elements.
It is therefore recommended that you turn ON the Element Iterative Solver in the "Edit
Solution" dialog.
Load/BC-Based Errors Summary
Nastran Model Setup Check completed
*** 07:25:31 ***
Starting Nastran Exporter
*** 07:25:31 ***
Writing file C:\dem\test\test1_sim1-solution_1.dat
*** 07:25:31 ***
Writing NX NASTRAN 11.0 compatible deck
*** 07:25:31 ***
Writing Nastran System section
*** 07:25:31 ***
Writing File Management section
*** 07:25:31 ***
Writing Executive Control section
*** 07:25:31 ***
Writing Case Control section
*** 07:25:31 ***
Writing Bulk Data section
*** 07:25:31 ***
Writing Nodes
*** 07:25:31 ***
Writing Elements
*** 07:25:31 ***
Writing Physical Properties
*** 07:25:31 ***
Writing Materials
*** 07:25:31 ***
Writing Degree-of-Freedom Sets
*** 07:25:31 ***
Writing Loads and Constraints
*** 07:25:31 ***
Writing Coordinate Systems
*** 07:25:31 ***
Summary of Bulk Data cards written
| NAME | NUMBER |
| CTETRA | 1357 |
| FORCE | 20 |
| GRID | 2965 |
| MAT1 | 1 |
| MATT1 | 1 |
| PARAM | 6 |
| PSOLID | 1 |
| SPC | 31 |
| TABLEM1 | 3 |
*** 07:25:31 ***
Nastran Deck Successfully Written
