Cold Form Stud Shear Wall Tie Down Strap - Will it Interfere with Densglass Instsallation
The detail below generated the following review comment from our architect: will the screws connecting the shear wall tie down straps to the metal studs interfere with the Densglass sheathing installation? You know, because they stick out a bit. Kinda seems like they might interfere. So my questions are these:
1) Is interference with the sheathing installation a legitimate issue?
2) What's the lowest low profile sheet metal screw that one can get?
3) Any other, better ideas? Simpson's got some twist straps that allow one to connect to the sides of the studs but I've not yet find one fully suitable.
Looking to move about 1500 lbs ASD.
RE: Cold Form Stud Shear Wall Tie Down Strap - Will it Interfere with Densglass Instsallation
Juston Fluckey, SE, PE, AWS CWI
Engineering Consultant
You might want to change your note regarding staggering you PAF's unless you give a minimum edge distance somewhere else in your notes. I believe 3" clear is what most manufacturer's recommend.
Dik
When you have straps crossing straps (for whatever reason) is when build-up is an issue.
It might be that your strap looks very thick as it is drawn in the detail. The thickness appears exaggerated and architects seem to base everything on what they see, not what they read...
