Multi tap trafo
Multi tap trafo
Hello to all
I am trying to find information about a multi tap transformer that was made by your company in the beginning of 1980's for Mazak Slant Turn 25 machine.
This multi tap transformer has the following characteristics:
5,8KVA
No. A029
BKO-NC6092H11
Best Regards
Kostas P. Sigounis
5,8KVA
No. A029
BKO-NC6092H11
Best Regards
Kostas P. Sigounis
RE: Multi tap trafo
http://www.emachinetool.com/usedcnc/catalog/vertical.cfm?ProductID=10192
http://www.emachinetool.com/usedcnc/categories.cfm?DestinationCategory=CNC%20Lathe
http://www.vikingmachinetools.com/machtool.htm?plngStockNo=2565
etc. for more info
RE: Multi tap trafo
That is a Mitsubishi part number(Yamazaki is Mitsubishi Electric's biggest customer so a lot of the products are OEM specials). Try contacting meau.com in Chicago.
Good luck
Grodno
