help!!! problem with pls-cadd
Geniuses of pls-cadd, I would like you to help me to solve that error, I get it when I give you the option to verify structure. I can not find the solution. Thank you.
RE: help!!! problem with pls-cadd
I would check the preferences and make sure you are not trying to write to a locked folder. If this is a real project of distribution poles and not one of the supplied examples, then make sure you have write rights in the folder. On some new PC's you may not be the owner of the folder and will have trouble saving files in the folder. You may have to reinstall PLS-CADD to get the rights correct. Look for a utility called takeownership and you can make the folder behave like you own it. It works to revise the registry but your company IT folks may not like it.
I would call PLS Tech support and let them figure it out, assuming you have a current license and have access to support.
Good Luck.
_____________________________________
I have been called "A storehouse of worthless information" many times.
permissions to folders as you mention, I've reinstalled the program too, this problem
only happens to me when I create the models with the PLS-POLE, when I create the model directly with the PLS-CADD
it does not give me any error, I attach the check model of the structure, and the screenshot of preferences.
I'm using the translator, sorry if there is any inconsistency.
Gracias!!
You might try just creating a small pole model from scratch in PLS-POLE with a single pole and a couple of joints and see how that works. Start small and work up.
We have all the materials for our PLS hardware keys, but you can license just wood, or steel, or concrete. Do you have the correct permissions to create models with different materials? When you first start up PLS-Pole, the splash screen should list the options for your hardware key.
If you have paid for support with PLS, you can get eMail help or phone them with support questions. I don't know if they have any Spanish speakers in their office but I would contact them for real help.
