battery backup for modem
I am seeking battery backup for modem (DSL & cable) for 12VDC 3Amp.
Is there readily available consumer grade 12VDC battery systems so that we can power our modem and recharge our cell phones/tablets when power goes our?
Otherwise, what is the circuit available to regulate & current limiting. Also splite out lower voltages for USB charging outputs.
I prefer using commercially available rechargable 12VDC lead acid batteries.
RE: battery backup for modem
https://www.phoenixcontact.com/online/portal/gb/?u...
Although not explicitly stated, I am fairly sure you could use a larger capacity battery than the 2.6AH type they suggest.
just home use for 12VDC battery power the modem and recharge cell phones & tablets.
> have connection for low cost 12VDC lead acid battery
> have both extension to recharge either by 110VAC or car cigarette plug
> have USB to charge cell phones & tablets
> DC female plug to power modem
quite like this mini DC UPS, but use inexpensive 12VDC rechargable lead acid battery
https://www.amazon.com/Application-Office-Power-Ou...
On one side, the charging options. You could add solar if you wish.
On the other side, the various DC or DC-DC outputs.
In the middle, the deep cycle lead acid battery.
The specificity of your requirements indicates that you're looking for an off-the-shelf solution.
but, if needed, I am willing to do some assembling, may be a markatable project and sell on Amazon?
Any comments?
The only reason that I bought it was that it was on clearance sale dirt-cheap; indication that the market is a tough place. Our ultimate solution was to purchase a desk phone that doesn't need any power other than that provided by the phone line. We may have to walk to the living room during power outages.
Incidentally, our present telephone, internet and one of our TV services, are via fiber optic cable. So the telephone line's power (the 48Vdc power and 90Vac Ringing Voltages) originates in the basement at the Optical Network Terminal (ONT) box. This box has a separate external power supply, and inside the power supply is - guess what? - a 12v 7A-hr lead acid battery to provide back-up so that the optical telephone line still works during power outages.
Like you, I've been eyeing the power supply (conveniently 12 Vdc) going to the connected Internet Wifi Router, wondering if it's worth providing a back-up power supply. Thing is, it's a lot easier to just turn on our smartphone's 'Hotspot' function. So I've not bothered.
Eventually I do plan to set up a 12 Vdc solar power system. But it's quite far down the list.
As I mentioned before, it's a fairly straightforward project. Just be very careful of the risks (e.g. install a fuse near the battery, etc.)
Good luck.
It looks like most of the Uninterruptible Power Supplies (UPS) use 6 volt batteries, however if you really want one that uses a 12 volt battery, take a look at this model: https://www.amazon.com/APC-Smart-UPS-1000VA-Batter...
Unfortunately this model doesn't include USB charging ports.
http://www.refurbups.com/CyberPower-RB1290X2-Repla...
https://www.cyberpowersystems.com/product/ups/rb12...
http://www.apc.com/shop/us/en/products/APC-Replace...
TTFN (ta ta for now)
Keith Cress
It's about modifying an inexpensive commercial UPS to extract the 12Vdc directly.
https://www.youtube.com/watch?v=-Ur-D37-juo
When our power went out caused by storms and triple digit super hot days, we desperately want to
1. Recharge the cell phones, tablets and laptops – 5V USB
2. Power the cable/DSL modem + WiFi router + VoIP phones – 12VDC
Only interested in cheap 12VDC rechargeable lead acid batteries – around $15 to $20
https://www.amazon.com/s/ref=nb_sb_ss_i_1_15?url=s...
Not interested in “Uninterrupted” Power Supplies. Not interested to power 120VAC desktop equipment.
I also think that you miss the point of the UPS, which is that they are turn-key solutions for your stated requirements. Moreover, their batteries are ostensibly chosen so that they can tolerate long periods of float charging.
You are correct. I always thought those little UPS batteries were 6 volts. Turns out they are 12 volts. The larger UPS used 2 batteries and I thought they were connected in series to make 12 volts. Apparently they are connected in parallel.
I learned something new today.
Microsoft Surface 3 is only 13W, recharge with USB, good for 9 hours. Sorry, no huge massive big screen i7 jobs. We are minimalist.
A $20 12VDC rechargeable lead acid battery at 7 Amp is 84W. Otherwise, get another battery stand by and swap in, meanwhile recharge the used unit in car?
Just the other week, I went through (charging, testing) four of those 12V, 7A-Hr lead acid batteries to see which were still good and which had died of neglect. Sadly, 50%.
Keith Cress
For nearly 10 years, I use a 24VDC electric lawn mower. It has two 12V small battery in series. It works well in around up 40 to 50 recharge cycles so far. I have never have to replace it (last chack its cost around $35 replacement battery).
$30 Multifunction Emergency Car Jump Starter
Keith Cress
At first I though you were meaning a large flooded lead-acid battery and since then you seem to be under-estimating your power requirements with the link to that cute little SLA battery. It will power just your 12V requirements for 70 minutes assuming you only discharge it to 50% capacity. Add a 2.1A USB device charging and you won't make it to 55 minutes. If the outage is significant then you'd have a vehicle running continuously charging batteries so you might as well just take power directly from it.
this car jumper is 8000 mAh / 400A for $32
https://www.amazon.com/gp/product/B0713T64TJ/ref=o...
this mini DC gets 15600 mAh for $45.39
https://www.amazon.com/gp/product/B073V1W455/ref=o...
It would be nice I can convert this to run off 12V rechargable lead acid battery
This is nearly what would work. Need USB charge output ports. Also need circuit to charge the battery circuit by car.
http://www.ebay.com/itm/DC-UPS-60W-12V-EU-Uninterr...
http://www.ebay.com/itm/DC-DC-12V-to-USB-5V-3A-Con...
The jumper pack Keith linked says 20Wh in the specifications. You'd get <30 minutes of run time powering a 12V at 3A load with that rating. I'm not sure where the 8Ah rating because 96Wh isn't close to 20Wh. Kind of makes one skeptical of the ratings for any similar Li-ion battery device.
You do know that the smaller SLA batteries can't just be connected in parallel with a car battery and then run the car to charge them? At least not without damaging them.
Your SLA would require a separate charger that would run off your car battery directly or through an inverter connected to your car battery
What's SLA?
During extended power outages, unplug the Ukrainian eBay gadget from the wall, and then plug it into a 12Vdc-to-120Vac inverter that is in turn connected to your other source of nominal 12 volts.
But a car idling in driveway for hours or days on end? Not a great idea. You might be surprised how much gasoline an idling car uses. At some point, a very small generator or a solar panel system starts to make sense.
One of the killer features that *could* be offered by future electric cars would be to provide emergency power back to the house during shorter power outages. It would need to be fully integrated, and intelligently controlled.
Dan - Owner
http://www.Hi-TecDesigns.com
