Echo meter utilization for tubing
Good Day,
We always use the Echo-meter for the fluid shot which will be taken inside the casing to measure the fluid level and calculate the down hole intake pressures.
Was echo-meter been used before in the well head to detect the tubing holes by the acoustic graph?
And how can it detect the holes? since detecting a tubing hole for an ESP well can be really confusing.
RE: Echo meter utilization for tubing
