Arrangement Driven Flexible Hose Routing Path
Hi. I'm constructing flexible hoses (deformable part) with the NX Routing function.
My problem is that when using an Arrangement Specific Distance Constraint to move one of of the two assemblies the Hose assembly is connected to (via routing port) the hose looses its port connection with the moved assembly and won't deform the routing spline.
As long as the distance constraint is edited manually (not being arrangement specific) the ports stay in place and the hose deforms as it should.
Video if the problem
Anyone got a solution or a suggestion?
Edit: Got an answer here
