Blast loading on process structures?
I know there are means and methods of designing Blast resistant "occupied buildings". However, for process structures which are very rarely occupied but could be housing blast capable equipments, do you ever consider blast loads while designing those structures? These are typically open structures - just a framework of beams and columns and grating. No roof or side walls. Is there anywhere in any Code that tells you to add or ignore blast loads for the process structures? Any help in this regard will be greatly appreciated.
-A
-A
RE: Blast loading on process structures?
The direction must also come from the client as to the level of damage they are willing to take in such a event.
Siting and Construction of New Control Houses for Chemical Manufacturing
Plants, (SG-22), Chemical Manufacturing Association.
An Approach to the Categorization of Process Plant Hazard and Control
Building Designs, (CIA), Chemical Industries Association.
Guidelines for Evaluating the Characteristics of Vapor Cloud Explosions,
Flash Fires, and BLEVEs, (CCPS) American Institute of Chemical
Engineers, Center for Chemical Process Safety
Guidelines for Evaluating Process Plant Buildings for External Explosions
and Fire, (CCPS) American Institute of Chemical
Management of Hazards Associated With Location of Process Plant Buildings,
(API RP 752) American Petroleum Institute
