Solidworks 2015 Installation
Hi Folks,
Got an issue in installing Solidworks 2015.It reads file missing "eulaeducational.htm".
Any help?
RE: Solidworks 2015 Installation
Yes.am installing an educational version.Any fix possible?
You will need to talk to your professor or the school you got it from. I have no clue how to fix it and SW knowledge base did not list a solution for that error.
Scott Baugh, CSWP pc2
CAD Systems Manager
Evapar
www.evapar.com
Quote:
"If it's not broke, Don't fix it!"
In continuation to this I tried installing a different copy of solidworks in my win 7 64 bitsp1.
I am getting an error "mmodules0.cab not found".I am trying with a solidworks 2010.
It sounds like you are trying to install from a memory stick or portable hard drive and the source you are using to install is either corrupt or missing files. I would try to get ahold of an original DVD copy.
Thanks a lot folks.By the way may I know which version is suitable for win7 64 bit sp1.Can I try with win8.Need your support please.
