Keeping shape integrity while using spline
First post! I'm currently making parts for an instruments company, more precisely trombone custom tubing. So lots of sweeps using a spline and a circle to make the parts. To bend this tubing we will be machining a mold of the parts, and once both halves are assembled with the tubing roughly bent within it we pass ball bearings through the tubing to smooth it out. Tolerances on the shape in the mold is +/- 0.001'', and the wall thickness for the brass tubing is about 0.04''.
All that being said there is very little margin for error, and the sweep that I'm creating needs to be perfectly round all the way through, if not the ball bearing will not go through the shape. How do I ensure that the sweep is perfectly round all the way through?
NOTE: I am also using the spline handles to achieve the particular aesthetic my client is looking for. I noticed that when too extreme it creates a bump in the shape of the part.
NOTE II: I also used the spline curve line to try and smooth it out as much as possible but some shapes are just sharp to smooth out completely.
Any words of wisdom are appreciated. :)
RE: Keeping shape integrity while using spline
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesCAD Systems Manager
Evapar
www.evapar.com
Jeff Mowry
www.industrialdesignhaus.com
A people governed by fear cannot value freedom.
