SA-312TP316L ID Surface
Currently working on a cryogenic piping project. Received fabricated pipe spools from client. Please Note: Spools have been sitting in a storage facility for three years. Pipe spools were checked for dimension & damage when end caps were removed it was noticed there were multiple ID surface conditions. One of the major conditions was spatter from initial fabrication (Plasma cutting)that goes quite a long way up the pipe the other concern was some of the straight lengths has a sand paper type of surface through out the length of pipe. We have taken one sample spool with the residual spatter & sandblasted it removed all of the residual spatter leaving a surface finish the meets SSPC SP-10 only concern was the blast medium had iron oxide in the blast medium. Once the fabrication is complete we will be completing pacification flush after hydo testing.
RE: SA-312TP316L ID Surface
