DISPLAYING UNIT CONVERSIONS IN MATHCAD EQUATION
Is there a way to display the unit conversion factors within the Mathcad equation without Mathcad calculating the conversion twice? I use Mathcad pretty extensively and many times I need to present calculations via a teleconference and I always get questions on the units and equations don't appear right. I know Mathcad calculates them in the background and I always state that but is there a way to display them just so the equation looks correct? For instance in the Formula, Torque based on Inertia and Time: Dynamic Torque=((Wk^2-inertia)(RPM))/((308)(time)) with 308 being the unit conversion factor.
Thanks in advance,
Scott
Thanks in advance,
Scott
RE: DISPLAYING UNIT CONVERSIONS IN MATHCAD EQUATION
TTFN (ta ta for now)
Perhaps you can post that part of your sheet.
If your clients need the "old" equation, then StevenAL's suggestion to use a text box is the way to go, rather than corrupt the calculations.
<rant=ON>
As long as you are using variables without units that are supposed to have them, you will always be fussing with extra "308" factors and confusing your clients.
When you get tired of micro-managing the units for MathCAD, just let MathCAD do the units for you. Start by giving all of your input values units.
Note that your 308 is inexact and missing some decimal places, like many others such as "g=32.2" and the divisor in the equations for power "5252" or "63025" or "1713" or "229" depending on whatever machine you're working on. Input the units properly, and you don't need any of this stuff. Forcing MathCAD to use them in the calculation adds error into an equation that does not need it. MathCAD - by design - handles units in the background whether you are using US, SI or CGS systems. It's one of the things I love about it, and I guess one of my pet peeves to see users who haven't discovered/accepted this.
<rant=OFF>
Thanks for reading
STF
What's cool about this is that if something changes, the old equation should give you the same answer as the Mathcad approach.
Do you assign units to the constant, and if so does it recognise sqrt(stress) as a valid unit, or is it handled differently?
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
But, for those that do exist, it's basically as I outlined above. You define your variables normally, with their correct units. Inside the empirical equation, you normalize the units to what's required for the formula, and then tack on the imposed units. That's my approach, and it allows you to use whatever units suit you outside of the empirical stuff, but retains all the essential information, particularly what units are required for formulas, without having to resort to text boxes to document things.
By retaining the units within the equations, it makes it more turnkey, which is particularly important if you come back 6 months later and try to use it again.
ugh, not in my definition of "properly"
Etc
The problem with "empirical formulae" such as your example where the tensile strength of concrete is given by:
f'ct = 0.36 * (f'c)^0.5
is that they are dimensionally inconsistent, and they only work if you enter the parameters in the required units. (The above example is from AS 3600, and gives the tensile strength in MPa if you enter the compressive strength in MPa - clearly it doesn't work if you enter the compressive strength in any other units, so the corresponding "empirical" relationship in American codes would use a different factor to obtain the equivalent "empirical fit" between compressive strength and tensile strength.)
My preferred approach for handling "empirical formulae" in dimensionally-aware software such as Mathcad is to define all parameters with their correct units, then whenever a dimensional parameter appears in an empirical formula, you divide all parameters by their units, making all parameters non-dimensional, and then finally multiply the whole expression by the implied units. E.g. for the above example, I would write:
f'c = 32 MPa
f'ct = 0.36 (f'c / MPa)^0.5 MPa
The first expression means that Mathcad "knows" that f'c carries units of "stress" or "pressure", and it will be quite happy whether you define it in MPa, psi, kgf/cm2, or whatever.
In the second expression, dividing f'c by its implied units makes it unit-less; so the expression can be evaluated correctly; multiplying the whole expression by MPa means that the solution for f'ct carries the required units.
If I want to know what the tensile strength is in psi or kgf/cm2, I just ask Mathcad to present the solution in alternative units of my choice. (This is very handy when doing a calculation to Australian or European codes, but needing to be understood by an American reviewer, for example.) If I want to know the tensile force carrying capacity of my concrete member, I multiply f'ct by the area of the section (which again carries appropriate units, whether it is square millimetres, square inches, or acres), and I can get the tensile capacity in kN, kips, kgf, or whatever.
http://julianh72.blogspot.com
Yes it does. The unit will the stress unit of your choosing raised to the 0.5 power, probably not what you're looking for. I suspect the k value isn't really unitless, and carries a unit that also looks like stress raised to the 0.5 power.
0.7*sqrt(fc) in SI units
7.5*sqrt(fc) in US units
However, when I solve for coefficient for the SI unit case using the US case, the coefficient is 0.62, not 0.7; 10% or so might not be a big deal, but this seems a bit sloppy and annoying.
The reason that the US and metric formulae yield different answers is that it's an empirical fit, and dimensionally inconsistent - hundreds of test samples have been plotted onto a graph, and a curve of best fit has been applied. Presumably, the committees responsible for the two expressions have used different subsets of data, or possibly are using different definitions of the strength (i.e. is it mean strength, or mean minus 1 x SD, or mean minus 3 x SD, or ...)
When you think about it, there is no theoretical basis for why the tensile or shear strength of concrete would be proportional to the square root of the compressive strength, it just happens to be a good fit for design purposes.
Regarding adding the units in the empirical code formula, I know Mathcad handles units, but as has been pointed out you have to be careful how you do it. I just happen to have done a blog post on how to do it with my units aware Excel spreadsheet (Working with implied units), so I was interested how Mathcad would do it. Thanks for the detailed responses above; I'll update the blog post with some more alternatives.
Doug Jenkins
The scatter in the empirical relationship is pretty wide, so it is not surprising that different codes use different expressions. Also, you need to be clear whether the strengths which are derived are flexural tensile strength or uni-axial tensile strength, and whether they are "typical" mean strengths, or lower-bound "characteristic strengths" - the codes will use different design factors depending on whether they are using a "typical" or "lower bound" strength.
E.g. take a look at this page:
"Relation Between Compressive and Tensile Strength of Concrete"
https://civil-engg-world.blogspot.com.au/2009/04/r...
Numerical Relationship
It is expected that these two types of strengths are closely related, but there is no direct proportionality. It is noticed that with the increment of compressive strength, the tensile strength is also increased but at a decreasing rate.
A better correlation is found between the various measures of tensile strength and the square root of the compressive strength. A number of empirical formulae connecting ft and fc´ have been suggested, many of them of the following type:
ft = k (fc)^n
where k and n are co-efficients. Values of n between ½ and ¾ have been suggested. The former value is used by the American Concrete Institute, but Gardner and Poon found a value near the later, cylinders being used in both cases. Probably the best fit overall is given by the expression:
ft = 0.3 (fc)^2/3
where, ft is the splitting strength, and fc´is the compressive strength of cylinders, both in megapascal. If the stress is expressed in pounds per square inch the co-efficient is replaced by 1.7. The above expression was suggested by Raphael. A modification of Oluokun is
ft = 0.2 (fc)^0.7
where the strength are in megapascals; the co-efficient becomes 1.4 in psi.
An expression used in British Code of practice BS 8007:1987 is similar, namely
ft = 0.12 (fc)^0.7
Clearly, these expressions can't all be "right", and they are clearly empirical fits as they dimensionally inconsistent, but they're all "good enough" for design purposes. (As long as you use all of the appropriate design rules from the respective design code - for example, a code which predicts a higher tensile strength for concrete will probably adopt a larger "material reduction factor" in the design rules.)
