STAADPRO gives different results
I have setup a model of a roof truss with Staadpro. The model was code checked with Chinese code and BS code. When I place the BS code check first (Parameter 1) for the members designed under BS code and Chinese Code check (Parameter 2) for built up member (I beam), the program reported all members passed. (Please ignore the tie rod bracings).
When I switched the parameters around, all the members failed. Not sure why. There may be a simple explanation but I am not seeing it. Please advice if anyone has any idea.
Below is the model in text.
http://files.engineering.com/getfile.aspx?folder=b...
Thanks.
Al
Thanks.
Al
RE: STAADPRO gives different results
The analysis output file ( File > View > STAAD Analysis Output ) on the other hand has the results for all design checks.
On a different note, if you are trying to do steel design as per Chinese design code, you should use the STAAD SSDD application. It can be downloaded from the same place from where you downloaded STAAD.Pro
I went to Bentley download page but couldn't find any SSDD application. Can you direct me to the application? Thanks.
Al
