FHWA Hydraulic Toolbox Stream Section Import
is there a way to enter a stream cross section into the channel analysis without manually defining in the cross section menu?
Import of TW file is referenced but no documentation is provided on HY 8 TW file format.
Any information is appreciated.
RE: FHWA Hydraulic Toolbox Stream Section Import
Station, Elevation, Manning's n
I did try creating a TW file based on the above mentioned format but still no results.
What I did find was if I cut and pasted from an excel file with the three fields, HY toolbox accepted the data.
