hello every body I am asking you
hello every body
I am asking you about changing property during steps of model
I need to change some material properties from one to another between first step to second step
how can I do this
plz help me
RE: hello every body I am asking you
with certain material models you can define stress-strain response as a function of temperature.
then you can vary temperature in different steps to vary mechanical response.
If the temperature is needed as a solution variable, then the same can be done with a Field Variable.
