Pipeline wall thickness for full vacuum
There is a 36" 6km long crude oil pipeline. Thickness is 9.5mm with 3mm corrosion allowance.
How do I verify if this thickness is sufficient for full vacuum condition?
Never forget what you are. The rest of the world won't. Wear it like an armor and it can never hurt you.
RE: Pipeline wall thickness for full vacuum
It will be ok.
XL83NL and KevinNZ,
Design code is ASME B31.4. It does not lead me to ASME BPV VIII Div1 UG 28. Only ASME B31.3 does. But my pipeline is not as per ASME B31.3. Even if I follow ASME VIII Div1 UG 28, what will be the value of L in L/D?
Thanks for your responses.
But should I really follow Section VIII here?
Thanks.
you need to calculate a fair number of items, but it's a recognized pipeline code.
If you're taking the min wt as 6.5mm, that's a D/t of 150 - pretty thin.
I think that's a bit excessive though, both as a CA and to remove the entire wt from the pipe calc.
You may well be in trouble at that sort of thickness.
31.4 states in a number of places that the pipe shall be designed with a margin of safety over buckling, but doesn't tell you how to do it....
multiplied to 36" gives a value of around 7mm.
Also this doesn't take into account any other forces, moments or axial stress, all of which could impact the final number.
apparently API RP 1111 has a formulae as well. Tried that and got a collapse pressure for 6mm pipe of 18 psi, but allowable is 0.7 of that so 13.2 psi.
http://fianagusta.blogspot.co.uk/2012/02/pipe-wall...
