UPDATING THE PART NAME AND DESCRIPTION FOR ITEM AND ITEM REVISION
When we update the Item Name and description in team center , it does not update the same for Item revision , please let us know is there a way to update the description for Item so that it will automatically reflects in other Dataset type including item Revision.
One more request is that If I need to change the part number and description for and item whether is there a way it will automatically reflect the updates in all the other data sets like
Item revision, UG mater & UG drawing.
Thank you
LG
Thank you
LG
RE: UPDATING THE PART NAME AND DESCRIPTION FOR ITEM AND ITEM REVISION
http://www.eng-tips.com/threadminder.cfm?pid=1521
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
