Sine Wave Filter output VFD
Hi.
Does anyone use the Mirus or MTE sine waves filter LCL at the output of vfds? Is the voltage waveform really sinusoidal?
Guilherme S.
BRAZIL
RE: Sine Wave Filter output VFD
No, but a lot more so than without it...
I use TCI's, but the concept is the same.
Without a filter:
With a filter:
" We are all here on earth to help others; what on earth the others are here for I don't know.
" -- W. H. Auden
Thanks.
Do you had problems with excessive drop voltage in motor? Mirus showed me that his creation with 2 windings, one opposite another winding dont have drop voltage.
do you know about it?
GS
Voltage drop is a potential (no pun intended) issue, but excessive is uncommon. I have never had it become an issue, but I have heard of it, only in applications where the motor was sized very very close to the required load.
Thanks.
GS
