(Applied Thermodynamics)__How to calculate the specific volume of water, at 100ºC and 1.5 bar?
The only data in the question is this table:
Do we have to do an interpolation between the point at 100ºc + 1.014 bar, the point at 110ºC+ 1.433 bar, and the point at 120ºC + 1.985 bar ?
What other suggestions you may have?
Thanks a lot!
Thanks a lot!
RE: (Applied Thermodynamics)__How to calculate the specific volume of water, at 100ºC and 1.5 bar?
http://webbook.nist.gov/chemistry/fluid/
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
Good luck,
Latexman
You need not look in to a table, again, once you download this.
