Dynamic Analysis v.s. Equvalent Static load
What are pros and cons of each method?
What you gain more from vibration/dynamic analysis that you cant get it from equivalent static load analysis/design?
My case is a vibration/rotating equipment on a structure?
Thank you
Thank you
RE: Dynamic Analysis v.s. Equvalent Static load
A static analysis isn't going to tell you if you have a vibration issue or not. It's a different animal.
May I ask please explain it a little bit more detail?
There is a suggestion that convert the dynamic load to an equivalent static load, simile impact load. I want to know what we will be missing if we check structure this way rather than doing a vibration analysis when checking the structure
Since what you are describing (i.e. rotating equipment) does not produce a single (short-term) load (in fact, it produces a sinusoidal load that is continuous)....not having a time-history analysis could fail to miss some important displacements. (Especially if the supporting structure's natural frequencies are close to the operating frequency of the equipment).
1) When the applied load is small relative to the total supported weight of the beam or structure: The load amplification method (when based on the eigenmode that is closest to resonance) tends to be a pretty conservative when compared to the results you get from a Time History Analysis.
2) The larger the load is relative to the overall weight of the structure, the less this can be said.
Think about it this way, a relatively small dynamic force doesn't have all that much total energy to move a much larger amount of mass. Especially when damping is considered. But, the larger that force gets (relative to the mass it is exciting) the more important it is to run a true dynamic analysis.
