Define the distance between the submerged circular beam center to the SWL in udf
Hi.
I am trying to use user defined function to define the buoyancy of the submerged beam in water.
The buoyancy can be determined by ρgVs. The submerged volume can be decided if we know the distance between the cross section center to the free surface. The problem is how to decide the distance between the cross section center to the free surface? Which function of user subroutine fit for this? Or is there any other way to define the submerged volume?
