Anchored Soldier Beam Wall Example
Does anyone know of a good design example/reference for an anchored (single and multiple) soldier beam wall? I have been tasked with updating a previous design (never built) to the current LRFD standards required by my state's DOT. The original engineer on this wall is no longer with the company and I don't fully agree with his methodology for the wall design so I am looking for some documentation to back up my reservations.
I have reviewed AASHTO and FHWA documentation, but am left desiring a little more information on the calculation process since this is not a space that I work in daily.
RE: Anchored Soldier Beam Wall Example
http://www.dot.ca.gov/des/techpubs/manuals/bridge-...
http://www.dot.ca.gov/hq/esc/construction/manuals/...
AASHTO provides a load factor of 1.35 on the apparent earth pressure (AEP) for the active pressure on anchored walls, but does not provide a reduction factor for the passive pressure resistance. Should there be a reduction factor applied to the passive pressure to meet LRFD requirements? I am leaning towards applying a 0.9 reduction factor on the passive to arrive at a FS of 1.5 which is inline with all of the references that I have read on this topic (pre-LRFD of course).
https://www.fhwa.dot.gov/engineering/geotech/searc...
This appears to be a good manual but because is dated on 1999 there is not LRFD consideration there:
https://www.fhwa.dot.gov/engineering/geotech/pubs/...
