A182 316L piping flange minimum temperature
Where is the minimum temperature associated with A182 316L piping flanges defined?
RE: A182 316L piping flange minimum temperature
If it's for B31.3, refer to table A-1; -425 °F *. You can go lower, refer to para 323.2.2. So the question stands; what exactly do you want or require?
Furthermore, if you want to use flanges at such low temperatures, make sure you have the correct bolting and gaskets to assure good leakfree sealing.
