Analysis of Layered Structure - Abaqus
I am analysing a layered structure with four layers one above the other. I have created all four layers and then assigned the required properties. Now I need to assemble four layers one above the other like a stack. What is the simple way to perform this action in Abaqus?
RE: Analysis of Layered Structure - Abaqus
in my point of view, you cret them in on part but you can assign each part alone with ur properties .
thanks
It depends on the purpose. In the Property-module is a composite layup tool, that can also be used for other materials. There you can create layups that can be assigned to shell, solid or continuum solid elements.
