Rebar Thermal Crack
Rebar Thermal Crack
In this case, I want to asking for rebar thermal crack. Area for pouring, length 37650mm, width 7660mm and height 3500mm. start concreting step 1 until height 1750mm. Forwarded step 2 until height 3500mm. Planned to be given rebar thermal crack 1/2 height (1750mm). How to calculate for this case? I want to plan use plain rebar 16-200? Is it appropriate for this case?
Is there a standard to calculate rebar termal crack.
Thank you.
Best Regards,
Hamzah
Thank you.
Best Regards,
Hamzah
RE: Rebar Thermal Crack
-Mac
