HS95 Sensor
HS95 Sensor
HS95 Sensor
Hi there,
Recently we were having issues with our HS95 Sensor for our LC1212 Amada Laser (1995).
So we ordered a HS95 and replaced it and now it wont cut at all.. goes to cut and doesn't pierce through the material.
Any suggestions?
RE: HS95 Sensor
did you calibrate head? "O8010" is the call out on my control which is different then urs but ur call out should be easy to find afro2
