Linear swell from CBR
Hello
What is the use of the linear swell from CBR test ? is it just to evaluate the efficiency of the chosen soil stabilization method ( as in hydraulically bound soils) or can you determine if the swell is dangerous or not, like in the case of free swell test on soils ?
RE: Linear swell from CBR
we (Virginia DOT) use the swell as a go/no-go criterion along with organic content, the actual CBR result, Atterberg limits and sand content (i.e., some group names are no good, by contract).
f-d
ípapß gordo ainÆt no madre flaca!
Thank you now i am starting to get some new info
so what are the threshold beyond which the swell is considered inadmissible
we use 5 percent.
f-d
i appreciate your help thanks
In Japan, normally 1% is used to define good subgrades.
EXPANSIVE SOILS by Nelson & Miller references Altmeyer (1955) and provides the following guidance about swelling soils:
  • less than 0.5% - Noncritical
  • 0.5%-1.5% - Marginal
  • greater than 1.5% - Critical
I find these values to hold true for floor slabs on grade in the central USA - but are somewhat on the conservative side for pavement.
Hi GM99, are those swells as measured in the CBR? I'll go get the citation, but in the interim remain curious. . .
f-d
you guys rock thank you
FATTDAD - Those swell guidelines are not from CBR tests but rather from One-Dimensional Swell Tests (ASTM D 4546).
