Thin Plates for Moment and Torsion connection
Hi guys,
I have a bit of an unusual situation. So, in reality I'm designing some stairs in which the flights/landings cantilever off of columns in the central well of the structure.
All sections of the structural members will be hollow section (beams and columns) and the senior engineer doesn't want to use hollo-bolts or anything similar.
His suggestion for the connection is illustrated in the picture below:
My concern is, this thin plate connection would need to resist bending plus torsion, would it be any effective in doing so? Or am I overthinking it?
If you have any suggestions on how to design the connection and make sure it works as intended that would also be great!
Thanks.
Thanks.
RE: Thin Plates for Moment and Torsion connection
Brian C Potter, PE
Simple Supports - Back at it again with the engineering blog.
I'd be more worried about the welds in bending (due to off-set loads).
Any ideas why this connections are usually considered pinned and not recommended for moment connections?
Brian C Potter, PE
I would prefer an HSS bracket shop welded to the column and extending to the outer beam. The inner and outer beams could bear on the bracket, preferably but not necessarily, on top of it.
BA
Sorry BAretired, what do you mean by HSS bracket shop?
BA
Structural, Alberta
It would not have enough stiffness to attract significant moment in a frame system. As a cantilever as you have it, I would be worried about slope of landing as others have mentioned. As BA mentioned could an outrigger be used? Even take it full width of landing.
